1999 Chevrolet Lumina No Crank
The first thing you should do is check the terminal connections on the battery. If they are corroded, then clean them and make sure you have a fully charged battery. You can remove the battery and take it to have it tested at any local parts store. I invested in a battery charger several years back, and it has paid for itself over and over.
If it wont start with a fully charged battery, then what is the engine doing? Is it turning at all, clicking, or just not doing thing?
With the water being an issue, it is possible that the water may have gotten in the starter and cause a problem. However, the starter should not be so easily messed up with water. It may just be a rare thing that just happened at the same time, and not have anything to do with the water.
If I were you, I would make sure I had a good fully charged battery and try it. If it doesnt turn at all, then I would suspect the starter or possibly a theft deterent problem.
I would next check to see if I am getting power on both terminals at the starter when it is trying to be started. If I have power on both, then the starter is bad.
There are two fuses you can check and see if they got blown while things were wet. The IGN 50a fuse in the Engine Wiring Harness Junction Block, and the fuse 7 5amp in your fuse block. The fuse box is inside the car, and the engine wiring junction block is under the hood. If one of these fuses is blown, put a new one in and try it. If it was wet, and now dry, it should be fine. If it is still wet, or you still have a problem, it will blow the fuse again.
The location of the starter is on the bottom side of the engine. You will need to jack the car and place supports under it before gettting under there. You should have a good view of the starter from the bottom.
Good luck
Suggested Repair
Clean and tighten the battery terminals, fully charge the battery, and have it tested. If it still will not crank, check the IGN 50A fuse in the under-hood engine wiring junction block and fuse 7 (5A) in the interior fuse block. Also check for power at both starter terminals while cranking; power at both points indicates a bad starter. The starter is on the bottom of the engine and requires the car to be safely jacked and supported. A theft-deterrent issue is also possible.
Conversation Summary
A 1999 Chevrolet Lumina 3.1 would not start after a lightning storm and possible water splash. It first cranked without starting, then later would not crank at all despite bright lights and working electrical accessories. The expert advised verifying a clean, fully charged battery, checking two specified fuses, and testing for power at both starter terminals. If both terminals have power, the starter is likely bad; a theft-deterrent problem is another possibility. The starter is accessed from under the engine.
