have spark have fuel at fuel rail but not getting fuel
ALLENR2024
ok I have 91 lumina just picked up, its z34 with the 3.4 dohc , problem I have is it has lots of spark, and when break fuel return line have or seem to have lots of preshure, yet will not start or even fire,but when I add fuel directly though plugs or though spray bottle into the thoughtal body it fires, and will run even ruffly as long as I keep sparying it in, so MY ? is what would cause me to have fuel at the fuel rack but nothing going into any cylenders?
was told ther was codes with the ignition control mod, but when I check it comes up clear no faults, and tested the modual and it seems to be working fine, lots of spark, so any ideas
Aug 12, 2007 at 1:26 PM
  • 75,988 POSTS
[quote:e0cebc52e4="AllenR2024"]ok I have 91 lumina just picked up, its z34 with the 3.4 dohc , problem I have is it has lots of spark, and when break fuel return line have or seem to have lots of preshure, yet will not start or even fire,but when I add fuel directly though plugs or though spray bottle into the thoughtal body it fires, and will run even ruffly as long as I keep sparying it in, so MY ? is what would cause me to have fuel at the fuel rack but nothing going into any cylenders?
was told ther was codes with the ignition control mod, but when I check it comes up clear no faults, and tested the modual and it seems to be working fine, lots of spark, so any ideas[/quote:e0cebc52e4]
Get a noid light hook it up on the injector connector is it being pulse by the PCM if not fuel will never get in the combustion chamber to be burn therefore no combustion.
Also won't hurt to check the fuel pressure with a fuel pressure gauge-opening the return line don't mean nothing. EFI is very picky on fuel pressure.
Aug 13, 2007 at 12:10 AM
