1999 Chevy Lumina Completely Dead
KEENGUITAR
HELP!
1999 Chevy Lumina, 135,000 miles ...in December, I went out to start it and the car was completely dead. No lights, no clicking no buzzer...no problems before then.
I jump start it, take it in have them check the battery and alternator, which had been replaced less then a year before...no problems there. They jiggle a few wires and suddenly it's fixed and I haven't had a problem since then. The car, in fact, set for a week in extemely cold temepratures while i was on a business trip and started up immediately when i came home
Until last night..ran fine no signs of trouble but this morning it's completely dead again...nothing works from headlights to door locks. Successfully jumped it and got it home but as soon as i turned it off, it was dead again.
Cables are tight with no obvious signs of wear or corrsion...beyond that, there's a lot of wires that I have no clue what they are. I jiggled them (the archair mechanic technique) but nothing
I welcome any advice at all..I don't think it's the starter or the battery or alternator....is there a short somewhere, a loose wire?
Feb 1, 2007 at 1:41 AM
JDL
  • 16,098 POSTS
Sorry for the late reply.
You shouldn't let the alternator charge up a dead battery, that hard on the alternator. I'd have to make sure battery has a full charge and the charging system is working properly.
Next, I have to check for too much battery drain, everything off. I haven't looked up the exact spec, usually around 30--50 ma, that is .030--,050 milliamps, not even a tenth of an amp. If the drain is too much, you pull/replace fuses one at a time, when you pull the fuse on the faulty circuit, the drain returns to normal. Then you check everything on that circuit. Sometimes a faulty alternator will let battery drain back through alternator.
Check for any lites left on, interior--under the hood, everywhere. Best time to check is in the dark.
Mar 20, 2015 at 7:16 AM
Suggested Repair
Fully charge the battery and verify the charging system before relying on the alternator to recover a dead battery. With everything off, measure parasitic drain (typically about 30-50 mA). If drain is high, pull fuses one at a time until it returns to normal, then inspect that circuit. Also check for lights left on and for an alternator that may be draining the battery.
Conversation Summary
A 1999 Chevrolet Lumina with 135,000 miles intermittently goes completely dead with no lights, locks, or starter click, then runs after a jump but dies again when shut off. Battery and alternator had tested fine earlier, and cables show no obvious corrosion. The expert advises confirming a full battery charge and proper charging, then checking for excessive parasitic drain by pulling fuses one at a time, including possible drain through a faulty alternator, and looking for any lights left on.
