Car loses power when accelerating
MENODITRE
I have a 1995 Chevy Lumina 3.1 liter engine with about 150 thousand miles on it. When you first start the car, until it gets warmed up, the RPM's will drop to about 500 and the car will lose power. If you press harder on the gas pedal the car will hesitate, then the rpms will shoot up, the car will go again and the RPM's will go back down. Also, after the car is warmed, if you turn it off (say, just long enough to get gas) and try to turn it back on it will either not start (it will just sputter out) or start roughly and then the RPm's will fly up to about 3000-400 on their own and then fluctuate for a bit and even out to an idle. I had the car to the shop just today, and it was throwing a code 51. They replaced my IAC, my PCV, my o2 sensors, my #5 fuel injector, the entire exhaust system, my map sensor, and a laundry list of various things. They also looked at my fuel pump and filter and said they were running well. The car sputtered on acceleration as I was pulling out of the lot. I took it back and the mechanic could not reproduce the problem. He said it would probably "even out on its own because replacing the PCV is like resetting the system " and that my car would need to re-learn what speeds it idles at, etc. The car ran great, for a few hours after that, but after leaving work tonight, it is running the same way it always did (minues the service engine light). what *else* could be the problem?
Aug 22, 2007 at 2:53 PM
  • 75,988 POSTS
[quote:0a884789ff="menoditre"]I have a 1995 Chevy Lumina 3.1 liter engine with about 150 thousand miles on it. When you first start the car, until it gets warmed up, the RPM's will drop to about 500 and the car will lose power. If you press harder on the gas pedal the car will hesitate, then the rpms will shoot up, the car will go again and the RPM's will go back down. Also, after the car is warmed, if you turn it off (say, just long enough to get gas) and try to turn it back on it will either not start (it will just sputter out) or start roughly and then the RPm's will fly up to about 3000-400 on their own and then fluctuate for a bit and even out to an idle. I had the car to the shop just today, and it was throwing a code 51. They replaced my IAC, my PCV, my o2 sensors, my #5 fuel injector, the entire exhaust system, my map sensor, and a laundry list of various things. They also looked at my fuel pump and filter and said they were running well. The car sputtered on acceleration as I was pulling out of the lot. I took it back and the mechanic could not reproduce the problem. He said it would probably "even out on its own because replacing the PCV is like resetting the system " and that my car would need to re-learn what speeds it idles at, etc. The car ran great, for a few hours after that, but after leaving work tonight, it is running the same way it always did (minues the service engine light). what *else* could be the problem?[/quote:0a884789ff]
If its an OBD1 do below, dunno if yours is fitted with OBD2
Warm the engine up to operating temperature turn the key off then jump pin A to B on the ALDl and turn the key on for 2 minutes then unplug the IAC (idle air control solenoid on the throttle body) then turn the key off, then start it you will have to keep it running by feathering the gas pedal, adjust the idle via the adjuster (you may have to remove the plug) till the engine idles at about 400-450 rpm, turn the key off reconnect the IAC let the engine cool disconnect the battery for 15 seconds and reconnect, start the vehicle set the parking brake and place it in reverse and let it run till the coolant fan cycles, then turn it off and you have just adjusted the minimum air rate and relearned the idle
Aug 22, 2007 at 7:48 PM
