Anti-lock and Brake (warning) light
CHEVROLET LUMINA
CARLOS1A
  • 5 POSTS
Family members and I have a total of 3 Luminas - all over 100K miles. Mine is a 95 and the other two are 96's. The Nti-lock light is activated on all three of them. Has been for some time. I wanted to know if there is a known problem with these cars?
I just changed the intake manifold gasket on the 95 just last week (3.1 V-6 engine). My new problem appeared when I was finished with the engine work. The brake warning light came on when I started it after re-connecting the battery - after everything was back together. Seemed strange to me, I did not disconnect or unplug anthing relating to the brakes. There are no leaks, the fluid level is fine, the emergency brake is fine (Like I said, I did not touch anything at all relating to the brakes) There is only one connector and it's under the master cylinder and it's plugged in. The anti-lock light in on this one too, not sure why. Any ideas?
Thanks,
Carlos
Mar 1, 2007 at 1:26 PM
RICHTER
Hello friend, I had the same problem a few months ago... I don't know why somethimes when you disconnect the battery this problem appear... but until this moment I have solved this problem scanning the engine and erasing the memory with the scanner... I know well that the memory would have to erase only disconnecting the batterry but apparently it doesn't erase at all... prove my solution, I hope it works for you as well as it works for me. Ah, and please tell me about your progress.
May 29, 2007 at 9:25 AM
NICKN
  • 69 POSTS
could also be just the brake sensors on the actual brake caliper. the anti lock light is on on mine as well and i have a 98. i was told thats all thats wrong with mine, cuz i just replace all calipers rotors and pads on mine.
Jun 11, 2007 at 10:20 AM
