air bag removal on steer wheel
CHEVROLET LUMINA
NOBULL44
1995lumina need to remove steering wheel w/ airr bag i need to replace the ingition switch thank you
Jul 30, 2007 at 12:44 PM
2CARPRO JACK
  • 11,533 POSTS
First turn ignition all the way off and remove the SIR or AIRBAG fuse. Then disconnect yellow SIR connector at base of steering column.Wait at least 2 minutes before removing the bag.Remove screws and nuts from underside of steering wheel and remove inflator module, then horn contact plate.Remove large nut holding wheel on, you will need a special puller to remove the wheel
Jul 31, 2007 at 1:12 AM
