AC cutting out when accelerating
HONEYBUNCH
I have a 94 Chevy Lumina APV. The Air works until you start to accelerate and then it is transfered to blow onto the floor from the dash or it just doesn't blow cold air. Is this a vacuum problem or a blockage?
Or could it be something else?
May 8, 2007 at 10:51 AM
PEGSUE53
[quote:73bda179d3="honeybunch"]I have a 94 Chevy Lumina APV. The Air works until you start to accelerate and then it is transfered to blow onto the floor from the dash or it just doesn't blow cold air. Is this a vacuum problem or a blockage?
Or could it be something else?[/quote:73bda179d3]I have a 96 Lumina Lemon and have the same problem. I have been told it is a vaccum problem. I have found that if I put the control, not on the max air or the air one but the one just above it, (I hope you understand what I am trying to say) Mine are in blue, there are three of them. One is like air circulation, max air and air. Any way I keep it on the like circulation one with the temp all the way on cold and I don't loose the air from my vents when I accelerate. Hope this helps
Aug 17, 2007 at 8:05 AM
