ABS Indicator Stays Illuminated
TOYORACTIS
Toyota Ractis Year: 2005 Mileage 2000km.
The ABS indicator would be illuminated after travelling for about 10km and stays on. After switching off the engine and upon restarting, the ABS lights will not light up immediately, but after travelling awhile, it will light up and stay lighted.
Had it checked by the local importer's appointed workshop, they reset the memory and the lighted ABS went out. However this only lasted a couple of days, subsequently it happens again!
Can any kind brothers advise what is the likely cause of this ? Is it dangerous to continue driving in this situation ? Thank you.
Feb 19, 2006 at 1:24 AM
FISHERMAN
  • 937 POSTS
there should be something wrong with your anti-lock braking system, have that checked.
Feb 19, 2006 at 7:09 AM
TOYORACTIS
[quote:341d344022="fisherman"]there should be something wrong with your anti-lock braking system, have that checked.[/quote:341d344022]
Thank you for your advise. Will get the workshop to re-check. Care to advise what are the likely areas that could be wrong with the ABS ?
Feb 19, 2006 at 3:00 PM
