92 lumina spitting and sputtering
PITMANR2003
I have a 1992 chevy lumina 3.1 v6, automatic, and it has 186,000 miles. It was running good till around a month or 2 ago. I accelerated kind of fast and the check engine light came on. It didnt seem to effect it any and when i shut it down and drove it the next day it didnt come back on. So i wasnt worried. Then it started comming on from day to day and got more frequent. when the light came on the car would have a slight miss every now and then. I checked the code and got a 42.
i let it go and it wasnt really bad till 2 days ago and it started running really ruff. like it was only running on 2 or 3 cylinders. then it would run fine again for a while and start again running bad when i restarted. when idleing it sounds like it is running without all cylinders.
Aug 18, 2007 at 4:31 PM
  • 75,988 POSTS
[quote:796bd0b228="mrsbones"]I have a 1986 grand marquie w/a 302 and it is not firing.it has always started right up, it just quit firing.
i am at my wits end it is my only tranportation. :?: :?: :?: :?:
please help i would be ever so grateful.
thank you so much,
Pam[/quote:796bd0b228]
Do you mean it doesn't crank over or cranks over and w/n start I need to know this
Aug 18, 2007 at 9:09 PM
MRSBONES
[quote:94b47d4d13="rasmataz"][quote:94b47d4d13="mrsbones"]I have a 1986 grand marquie w/a 302 and it is not firing.it has always started right up, it just quit firing.
thank you so much,
Pam[/quote:94b47d4d13]
Do you mean it doesn't crank over or cranks over and w/n start I need to know this[/quote:94b47d4d13]
it will not start at all
Aug 19, 2007 at 3:57 AM
MRSBONES
Aug 19, 2007 at 4:01 AM
  • 75,988 POSTS
[quote:cc02c39df9="mrsbones"]it will not start at all[/quote:cc02c39df9]
Try disconnecting a plug wire and ground it to the engine while cranking over-Do you have spark?
Aug 19, 2007 at 9:45 AM
