2006 Chevy Lumina engin oil run out too fast
2006 CHEVROLET LUMINA
WAHID123
Engine Mechanical problem
2006 Chevy Lumina 6 cyl Two Wheel Drive Automatic
i think i have an oil leakage in my car engine because whenever i put oil its run out very fast also when i start the engine a white smoke come out from the exhaust
Oct 2, 2009 at 12:54 AM
RENAUDTN
  • 636 POSTS
Usually white smoke indicates a coolant leak. If oil leaks into the cylinder, you’ll have blue-ish smoke coming out of your tail pipe. Do a compression test on each cylinder to find out which one(s) is/are leaking. Are you sure your oil isn’t leaking from anywhere else (oil filter, oil pan, valve cover, timing cover, crankshaft seals etc)?
Oct 2, 2009 at 8:35 AM
