2006 Chevy Lumina AC Turn Off and On by itself
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOHAMMADAWAD
Hi, I had an issue with my car's AC, when i turned the AC on, after couple of minutes letus say 5 minutes it turns Off by itself for 2 secends and back On again, after that it does the same every 2 minutes.
Aug 30, 2010 at 9:49 PM
WRENCHTECH
  • 20,760 POSTS
Are you referring to the blower starting and stopping or the compressor?
Aug 31, 2010 at 12:13 AM
MOHAMMADAWAD
everything stop working, the AC has a digital screen .. so when it turns OFF everything disappear from the screen, it looks like i didn't turn it ON at all, then after 2 or 3 seconds it back ON again, the screen shows the data again and the fan works again !!
Aug 31, 2010 at 12:25 AM
WRENCHTECH
  • 20,760 POSTS
That's either going to be a problem with the power supply coming into the power head or a bad power head itself, probably the latter.
Aug 31, 2010 at 12:51 AM
MOHAMMADAWAD
Thank you very much.
Aug 31, 2010 at 1:15 AM
