2005 Chevy Lumina heater control
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
L. D. HILBERN
car has a driver control lever and passenger control lever on dash for heat and air . all seems to be working, except. no heat at all on drivers side of car.Is problem behind the dash,or under the hood
Oct 30, 2009 at 3:55 AM
  • 110,248 POSTS
There are vents that open and close under the dash. They allow the air to enter the vehicle as directed. Chances are there is a vacuum leak on one of them that is causing one not to open. THerefore, I would start by looking for vacuum leaks under the dask. With the engine running, you may be able to hear a hissing sound from the leak.
Let me know what you find.
Nov 16, 2009 at 12:12 AM
