2001 Chevy Lumina thermostat
LELABIEHL
Engine Cooling problem
2001 Chevy Lumina 6 cyl Two Wheel Drive Automatic
what is the easiest way to change the thermostat
Aug 27, 2010 at 11:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Follow top rad. hose to block there it is in that housing. Drain coolant, unbolt. clean off gasket replace and fill. to the left side top engine see a tube and a small bleeder valve open this to remove air.
Aug 27, 2010 at 11:24 AM
