2001 Chevy Lumina surging
2001 CHEVROLET LUMINA
198,000 MILES • 6 CYL • FWD • AUTOMATIC
WORF55381
car startrs hrd need to give it gas after car warms up it surges 500 to 1500 in park or nutral and will die when at a light or slow rpm 1200
Jan 22, 2009 at 7:55 AM
JDL
  • 16,098 POSTS
Hello, If you open the throttle a little during cranking, your bypassing the iac system, I can't say it is faulty, just a thought. If you floor the pedal, it may cut off the injectors. Can you check fuel pressure? A vacuum leak or sensor problem might cause a surge.
Can you check for codes? Some of the national brand auto stores will check some codes for free, if you can get it down there.
Jan 22, 2009 at 8:55 AM
