2001 Chevy Lumina Fans will not work
158,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDFORBAMA
Heat only blows cold air/temp gauge does not even move/both fans on radiator are not coming on/checked fuses and sensors all ok/ will changing thermo correct problem or what other direction
May 10, 2010 at 4:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
thermostat is most likely stuck open, need to remove and test it.
May 10, 2010 at 5:31 AM
