2001 Chevy Lumina
244,000 MILES • V8 • 2WD • AUTOMATIC
BURNSJ2479
2001 lumina, will not crank over, security light blinks and brake light comes up,
Oct 3, 2010 at 4:21 PM
  • 110,248 POSTS
If the security light is coming on, that is shuting the engine off. The security system needs to be scanned to identify where the problem is coming from. You can try a different key if you have one. Otherwise, and I hate to say it, it needs taken to a dealer to have the system scanned. They are the only ones with the proper test equipment to check it.
NOTE: If you turn the key to the run position for aprox 10 minutes, the security light should shut and the engine should start.
Oct 8, 2010 at 5:18 AM
