2000 Chevy Lumina Turn Signal switch
120,000 MILES • 6 CYL • FWD • AUTOMATIC
DOG1
Recently my right trun signal would not blink unless I only pushed gently on the switch. If it was engaged no turn signal. The left pisition worked fine before but now it has become intermitten in operation. Today the windshild washer switch will not work and the pump checks out OK. I fear it is the cluster that may be bad but I don't know how to check ot remove it. Any suggestions as to how to fix this or what manual would be helpful.
Mar 20, 2008 at 2:04 PM
2CARPRO JACK
  • 11,533 POSTS
You can go here
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
and sign up for an online manual, printable instructions and pics. Your problem sounds like the turn signal switch is falling apart internally if you can hold it up (right) and it works. Pretty sure your comes with the controls for all of what you are having trouble with
Mar 21, 2008 at 12:57 AM
