2000 Chevy Lumina Shifting Problems
169,000 MILES • 6 CYL • FWD • AUTOMATIC
PCTECH45
I bought a 2000 Chevy Lumina for $500.00. It has several problems, one of which has already been fixed (water pump, intake manifold gasket).
However the transmission is another case. It will not shift correctly and it will not go into overdrive. I also hear a loud whining sound (and no it isn't my ex-wife!). I was told the fix may not be a major repair but I wanted to find out from someone here if they thought they knew what could be the problem.
I have a line on a transmission for $350.00 if this one is trash.
Mar 12, 2010 at 2:20 PM
FACTORYJACK
  • 4,159 POSTS
If you have noise and it is determined to be from the transmission, it can be considered major. The problem is, with the miles that you have on it, and without knowing the service history of the vehicle, you don't know the severity until the box is out and disassembled, and that is major. The shifting concerns could be isolated to the valve body, but to say 'try a valve body', would be a shot from the hip, and it could get you at or over the $350 that you would spend on the other trans. What is the condition of the fluid, this could be somewhat of a tell-tale sign to if there is something going on inside, unless it has been changed. Is the fluid off color, or smell burnt, this is an indication that it has been overheated, and there is some clutch distress. Also a removal of the pan can give an idea, is there sediment or metal particles. By stating no overdrive, do you just have three gears? 4th would be overdrive(0.705:1), or is it that the TCC isn't applying? The TCC is an issue that can be either serviced in vehicle, or require removal.
Mar 13, 2010 at 4:55 PM
PCTECH45
The car was leaking radiator fluid through the intake manifold gasket and water pump. Both items were replaced. So there is history of running the car while extremely hot.
The transmission fluid was at least a quart low but it was not off-color and still maintained the red color indicative of normal wear and tear.
I've heard people say the torque converter could be out, or that there is an electronic sensor inside the transmission somewhere that could be malfunctioning.
What do you think?
Mar 14, 2010 at 3:37 AM
FACTORYJACK
  • 4,159 POSTS
A torque converter can have noise, and it might cause shifting problems, it won't make you lose a gear. Here is some torque converter diagnostic infoThe Torque Converter Clutch (TCC) is applied by fluid pressure, which is controlled by a PWM solenoid valve. This solenoid valve is located inside of the automatic transmission assembly. The solenoid valve is controlled through a combination of computer controlled switches and sensors.
Torque Converter Stator
The torque converter stator roller clutch can have two different malfunctions.
• The stator assembly freewheels in both directions.
• The stator assembly remains locked up at all times.
Poor Acceleration at Low Speed
If the stator is freewheeling at all times, the car tends to have poor acceleration from a standstill. At speeds above 50-55 km/h (30-35 mph), the car may act normally. For poor acceleration, you should first determine that the exhaust system is not blocked, and the transmission is in First gear when starting out.
If the engine freely accelerates to high RPM in NEUTRAL, you can assume that the engine and the exhaust system are normal. Check for poor performance in DRIVE and REVERSE to help determine if the stator is freewheeling at all times.
Poor Acceleration at High Speed
If the stator is locked up at all times, performance is normal when accelerating from a standstill. Engine RPM and car speed are limited or restricted at high speeds. Visual examination of the converter may reveal a blue color from overheating.
If the converter has been removed, you can check the stator roller clutch by inserting a finger into the splined inner race of the roller clutch and trying to turn the race in both directions. You should be able to freely turn the inner race clockwise, but you should have difficulty in moving the inner race counterclockwise or you may be unable to move the race at all.
Noise
Important: Do not confuse this noise with pump whine noise, which is usually noticeable in PARK, NEUTRAL and all other gear ranges. Pump whine will vary with line pressure.
You may notice a torque converter whine when the vehicle is stopped and the transmission is in DRIVE or REVERSE. This noise will increase as you increase the engine RPM. The noise will stop when the vehicle is moving or when you apply the torque converter clutch, because both halves of the converter are turning at the same speed.
Perform a stall test to make sure the noise is actually coming from the converter:
Place your foot on the brake.
Put the gear selector in DRIVE.
Notice: You may damage the transmission if you depress the accelerator for more than 6 seconds.
Depress the accelerator to approximately 1,200 RPM for no more than six seconds.
A torque converter noise will increase under this load.
Torque Converter Clutch Shudder
The key to diagnosing Torque Converter Clutch (TCC) shudder is to note when it happens and under what conditions.
TCC shudder which is caused by the transmission should only occur during the apply or the release of the converter clutch. Shudder should never occur after the TCC plate is fully applied.
If the shudder occurs while the TCC is applying, the problem can be within the transmission or the torque converter. Something is causing one of the following conditions to occur:
• Something is not allowing the clutch to become fully engaged.
• Something is not allowing the clutch to release.
• The clutch is releasing and applying at the same time.
One of the following conditions may be causing the problem to occur:
• Leaking turbine shaft seals
• A restricted release orifice
• A distorted clutch or housing surface due to long converter bolts
• Defective friction material on the TCC plate
If Shudder Occurs After TCC has Applied
If shudder occurs after the TCC has applied, most of the time there is nothing wrong with the transmission.
As mentioned above, the TCC is not likely to slip after the TCC has been applied. Engine problems may go unnoticed under light throttle and load, but they become noticeable after the TCC apply when going up a hill or accelerating. This is due to the mechanical coupling between the engine and the transmission.
Once TCC is applied, there is no torque converter (fluid coupling) assistance. Engine or driveline vibrations could be unnoticeable before TCC engagement.
Inspect the following components in order to avoid misdiagnosis of TCC shudder. An inspection will also avoid the unnecessary disassembly of a transmission or the unnecessary replacement of a torque converter.
• Spark plugs - Inspect for cracks, high resistance or a broken insulator.
• Plug wires - Look in each end. If there is red dust (ozone) or a black substance (carbon) present, then the wires are bad. Also look for a white discoloration of the wire. This indicates arcing during hard acceleration.
• Coil - Look for a black discoloration on the bottom of the coil. This indicates arcing while the engine is misfiring.
• Fuel injector - The filter may be plugged.
• Vacuum leak - The engine will not get a correct amount of fuel. The mixture may run rich or lean depending on where the leak occurs.
• EGR valve - The valve may let in too much or too little unburnable exhaust gas and could cause the engine to run rich or lean.
• MAP/MAF sensor - Like a vacuum leak, the engine will not get the correct amount of fuel for proper engine operation.
• Carbon on the intake valves - Carbon restricts the proper flow of air/fuel mixture into the cylinders.
• Flat cam - Valves do not open enough to let the proper fuel/air mixture into the cylinders.
• Oxygen sensor - This sensor may command the engine too rich or too lean for too long.
• Fuel pressure - This may be too low.
• Engine mounts - Vibration of the mounts can be multiplied by TCC engagement.
• Axle joints - Check for vibration.
• TP Sensor - The TCC apply and release depends on the TP Sensor in many engines. If the TP Sensor is out of specification, TCC may remain applied during initial engine loading.
• Cylinder balance - Bad piston rings or poorly sealing valves can cause low power in a cylinder.
• Fuel contamination - This causes poor engine performance.
Torque Converter Evaluation and Diagnosis
Replace the torque converter if any of the following conditions exist:
• External leaks appear in the hub weld area.
• The converter hub is scored or damaged.
• The converter pilot is broken, damaged, or fits poorly into the crankshaft.
• You discover steel particles after flushing the cooler and the cooler lines.
• The pump is damaged, or you discover steel particles in the converter.
• The vehicle has TCC shudder and/or no TCC apply. Replace the torque converter only after all hydraulic and electrical diagnoses have been made. The converter clutch material may be glazed.
• The converter has an imbalance which cannot be corrected. Refer to Flexplate/Torque Converter Vibration Test .
• The converter is contaminated with engine coolant which contains antifreeze.
• An internal failure occurs in the stator roller clutch.
• You notice excessive end play.
• Overheating produces heavy debris in the clutch.
• You discover steel particles or clutch lining material in the fluid filter or on the magnet, when no internal parts in the unit are worn or damaged. This condition indicates that lining material came from the converter.
Do not replace the torque converter if you discover any of the following symptoms:
• The oil has an odor or the oil is discolored, even though metal or clutch facing particles are not present.
• The threads in one or more of the converter bolt holds are damaged. Correct the condition with a new thread inset.
• Transmission failure did not display evidence of damaged or worn internal parts, steel particles or clutch plate lining material in the unit and inside the fluid filter.
• The vehicle has been exposed to high mileage only. An exception may exist where the lining of the torque converter clutch dampener plate has seen excess wear by vehicles operated in heavy and/or constant traffic, such as taxi, delivery, or police use.
There are several electronic components within the trans that can fail. If an electronic component is failing, it usually is recognized, and sets a code illuminating the check engine light. A mechanical problem could be a sticking valve, leaking seal, leaking within the case, and so on. This may or may not set a code. If you have shifting problems, missing a gear, and noise, those are three different symptoms that can have three different causes. The fact that the fluid may be clean could, and most likely at 170k, indicate that the transmission was flushed in attempt to correct a concern.
Mar 14, 2010 at 4:44 AM
PCTECH45
I think all that just justified a visit to the local transmission shop. There is just too much for a local yocal like myself to competently make a good diagnosis.
Hopefully a check up won't cost me too much, but if the repair bill is going to be too much then I'm just going to have it replaced.
Thanks for your help.
Byron
Mar 14, 2010 at 9:28 AM
FACTORYJACK
  • 4,159 POSTS
That is a good idea. To say it is something simple, on a vehicle sight unseen, would be just the same as saying it is something more involved. On a transmission, without being able to experience it, I could try and explain to you the endless possibilities. We could either nail it, or end up in frustration. We appreciate your contribution and participation.
Mar 15, 2010 at 2:48 PM
