2000 Chevy Lumina Lumina stalling in warm weather not in co
JM3
  • 2000 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 80,000 MILES
Hello and thanks,
I've been having a problem for about a year or so with my 2000 Chevy Lumina. It stalls out at stop lights or when idling for a period of time when the weather is warm but not in cold weather? It will start right up but I have to give it a little gas some times. I have also noticed on occation that it surges as I'm waiting a stop light.
I replaced the IAC, plugs and wires, fuel filter, air filter so far. It doesn't throw any codes.
I'm planning on replacing the TPS next. What do you think?
Thank you again
Wednesday, January 30th, 2008 AT 4:42 PM
DNAPRORACING
  • 120 POSTS
See if you're getting too much back pressure from the cat.
Gary
Thursday, January 31st, 2008 AT 9:29 AM
JM3
  • 8 POSTS
Thanks for the reply. Is it possible for a shade tree mechanic such as myself to check the catalytic converter? What is the easyest way? The car doesn't overheat, and the cat isn't "glowing" from overheating. It is something think about though. Thank you.
Thursday, January 31st, 2008 AT 12:28 PM
INDYPAPAJOE
I had same prob. Check your fuel regulator and 02 sensor.I changed my fuel reg. And it ran great, but now 02 sensor is waring down. Good luck
Saturday, March 8th, 2008 AT 11:21 AM
JM3
  • 8 POSTS
Thanks for your reply. I changed the fuel regulator and my problems are solved!
Saturday, March 15th, 2008 AT 9:22 AM
