2000 Chevy Lumina Ignition Switch
145,000 MILES • 6 CYL • FWD • AUTOMATIC
INTIKHAB71
When i try to start the car ,there is no sound at all. I feel the switch is free when i trun it around
Do i need to repair switch or i i can buy a new one. Which should i buy if i have to ?
Little are working, power doors, fan is working also, i mean battery is fine.
If in case i have to change the switch , what happens with the security code.
May 20, 2008 at 12:52 AM
RHALL77
  • 3,361 POSTS
first i would check and see if you are getting voltage to the starter when turning the key to the start position.
May 20, 2008 at 1:04 AM
