car overheating replaced the water pump did not work was told the head gaskets were probably damaged and leaking used red devil to seal all the gaskets, however the mechanic did not replace the thermostat instead left it with no thermostat could this be why it is still getting hot the car is not blowing any smoke there is no water in the oil and no unusual noises
Mar 23, 2010 at 10:09 AM
