2000 Chevy Lumina hard shifting
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLARENCE MASTERS
Sometimes this car hard shifts into gear. So far I have been unable to relate it to the way I drive, the heat or the length of time it has been turned off. Many times after it has sat in a parking lot (off) for a few minuts it is just fine. It may be just fine for the rest of the trip or it may start to hard shift after only a few miles I have driven it for weeks without a problem and then the next time I back it out of the driveway it starts to act up.
Aug 6, 2009 at 7:07 AM
BRIAN 1
  • 1,030 POSTS
I would check the fluid level and make sure the fluid is not burnt,I would also scan for codes.it sound like a pressure control solenoid,this has all the symtoms and it was a very common problem on these.
Aug 8, 2009 at 6:03 AM
