2000 Chevy Lumina Brake lights out along with blinkers and
PSYCHEDELIC
Electrical problem
2000 Chevy Lumina 6 cyl Two Wheel Drive Automatic
Car sat for awile at least 1 year can only assume that thay worked before the car was stoped
Jun 1, 2009 at 6:06 AM
BMRFIXIT
  • 19,053 POSTS
Use 4 way flasher
do they work
step on the brakes does the 3rd light work
suspect and check fuses
flasher relay
multifunction switch
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Jun 1, 2009 at 6:34 AM
