2000 Chevy Lumina back door
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
RDRNER9
needs the door latch replaced. it is stuck closed keeping the door from closing This has happened before when i have used the chid safty lock. How much should it cost to replace or is it something a non perfessional could do with a little instruction
Jan 9, 2010 at 4:16 AM
  • 110,248 POSTS
Actually, it shouldn't be too hard for you. Once you remove the door panel, it is just a matter of unbolting the latch and removing the linkage to it. You should be able to do it.
Have you taken a look at it?
Jan 19, 2010 at 4:20 AM
