1999 Chevy Lumina wont run
FATBOYC2
Engine Performance problem
1999 Chevy Lumina 6 cyl Two Wheel Drive Automatic
The car will crank up and run like a dream for about 15 min. then it goes dead and don't wont to start back up and there is no codes. I have just replaced the fuel pump. I think it may be in the coil pack but don't know how to check it.
Aug 18, 2010 at 2:30 PM
  • 110,248 POSTS
What I need you to do is check to see if the engine is getting spark and fuel when this happens. One will be missing. Here are directions for checking both.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Let me know what you find.
Aug 21, 2010 at 3:33 PM
FATBOYC2
we have fuel and spark still no codes like I said before it will crank up and run for about 15 to 20 mins. thin it shuts off and will only try to crank up if you hold the gas peddle down or let it cool off.
Aug 22, 2010 at 9:28 AM
  • 110,248 POSTS
Have you checked fuel pump pressure when it doesn't start? Will it start with starting fluid in these cases?
Aug 22, 2010 at 4:27 PM
