1999 Chevy Lumina Whistling dixie...
180,000 MILES • 4 CYL • FWD • AUTOMATIC
SWEETIRISHROSES
Hello, I have a 1999 Chevy Lumina 3.1 engine, It started out as a low pitched whistle that would only occur on stopping, I thought it was the breaks, but the noise continued after stopping. Now, it is a audible whistle, I opened the hood thinking maybe it was a vacuum hose, but the whistling is coming from under the car. And it goes all the time now. Could you give me some ideas on what it could be? It almost sounds like the whistle of a vacuum cleaner. Any help would be great. :)
May 28, 2010 at 2:27 PM
BMRFIXIT
  • 19,053 POSTS
do you have check engine light on ?
if so check for codes
codes may offer some pin points to what is going on
if its an engine or tranny issue
check intake manifold gasket
May 28, 2010 at 10:52 PM
