1999 Chevy Lumina water leak around water pump, but not at
1999 CHEVROLET LUMINA
WALTER MCKINNEY
Engine Cooling problem
1999 Chevy Lumina 6 cyl Front Wheel Drive
Can't find where water leak is at, have repakced
water pump, but leak is under and away from water
pump, were or waht could it be?
Mar 2, 2009 at 1:56 PM
  • 110,244 POSTS
Hi:
Have you tried to pressurize the system and locate it that way? also, they make a dye that you can use. It wil glow under a black light so you can see where the leak is coming from.
As far as under the water pump, there really isn't anything there unless the rad hose is leaking.
Let me know ifthe suggestions help.
Mar 7, 2009 at 2:20 PM
BOBBY LANCASTER
  • 87 POSTS
check radiator cap
Jan 2, 2010 at 5:36 AM
