1999 Chevy Lumina Washer motor
OCEANSHAWN
1999 Chevy Lumina
My windshield motor stopped working all of a sudden after I filled it the last time, I can't find which fuse controls it to see if that is the problem or not. If that is not the problem what do you think it may be?
Dec 30, 2009 at 1:27 AM
HMAC300
  • 48,601 POSTS
if you still have a book that came with a car that will show location of all fuses. But washermotors will just quit working. First get a test light to make sure it is gettin power when the switch is tripped. ten listen carefully to see if it is working as the squrter may be clogged at the wiper itself. YOu mayneed a very fine wire to run down it to clean it out.
Dec 31, 2009 at 1:57 AM
