1999 Chevy Lumina trans will not shift
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
FUNLOVINGLIBAR
The trans is in gear and can not be shifted with the shift lever.
the cable is not broken.
I can not shift the trans lever by hand with the cable removed.
Dec 29, 2007 at 2:37 AM
DENNYP
  • 1,824 POSTS
You could have a damaged manual shift valve in the valve body. You will need to remove the trans side cover to see what's going on.
Dec 29, 2007 at 4:22 AM
