HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine Cooling
Thermostat
1999 Chevy Lumina tHERMOSTAT
RANDY ADAIR
MEMBER
1999 CHEVROLET LUMINA
6 CYL
FWD
AUTOMATIC
180,000 MILES
WHERE IS THERMOSTAT ON THE 3.1 V6?
Friday, January 16th, 2009 AT 11:25 AM
RENAUDTN
MECHANIC
Follow upper radiator hose to engine block.
The hose connects to the engine at the thermostat housing. The thermostat is inside the housing.
I suggest you buy a Haynes/Chilton manual to help you replacing it. You can find used ones for dirt cheap.
Good luck.
SPONSORED LINKS
Friday, June 21st, 2019 AT 3:05 PM
Please
login
or
register
to post a reply.
Related Thermostat Content
How To Change A Thermostat
How I Change The Thermostat?
Asked by
michaeldroopy
1 ANSWER
2 IMAGES
1999
CHEVROLET LUMINA
VIDEO
Thermostat Replacement Chevrolet Blazer
Instructional repair video
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
1999 Chevy Lumina Thermostat
I Am Wondering How To Get To The Thermostat. What Do I Have To Remove In Order To Get To The Bolts. Everything Seems To Be In The Way And I...
Asked by
tbone007
1999
CHEVROLET LUMINA
Thermostat
How To Change A Thermostat On A 1999 Chevy Lumina
Asked by
glot31
1 ANSWER
1999
CHEVROLET LUMINA
Thermostats
What's The Best Way To Replace Athermostat On A 2000 Lumina
Asked by
htown
3 IMAGES
2000
CHEVROLET LUMINA
Thermostat
How Do You Change The Thermostat On A 2000 Chevy Lumina
Asked by
e_johnson_31
1 ANSWER
2 IMAGES
2000
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
Thermostat Replacement Ford
Thermostat Replacement Mercedes Benz C230
Thermostat Replacement Chrysler
Online car repair manuals
