1999 Chevy Lumina radiator fluid leak
SCOSIDE
Engine Cooling problem
1999 Chevy Lumina 6 cyl Front Wheel Drive 210000 miles
leaking from the rear bottom left of engine area but can not see exactly where. I don't even know where the water pump is. any ideas? afraid it's probably not good.
May 26, 2009 at 10:47 AM
RENAUDTN
  • 636 POSTS
Your water pump is located in front of your engine (remember your engine sits sideway) where the serpentine belt is. To find it just follow your lower radiator hose; it goes straight to your water pump.
May 27, 2009 at 7:34 AM
SCOSIDE
Do you have any idea based on the location where it could be leaking from? Again it was left lower rear of engine.
May 27, 2009 at 10:14 AM
RENAUDTN
  • 636 POSTS
If you’re leaking coolant at the engine, it usually comes from one of the following: hoses, the thermostat housing (where the upper radiator hose connects to the engine), intake manifold (gasket), and water pump.
Since you said it is located on the rear of the engine that would rule out your water pump.
Check the hoses at/around the thermostat housing, the housing itself, and your manifold.
May 28, 2009 at 1:39 AM
