power window motor?
150,212 MILES • 6 CYL • 2WD • AUTOMATIC
KHOUGH1956
How do I remove and replace the driver side front power window motor
Mar 7, 2009 at 7:31 AM
  • 110,248 POSTS
Certainly, here's a general step-by-step guide on how to remove and replace the driver side front power window motor in a 1999 Chevrolet Lumina. Keep in mind that vehicle models can vary, so it's always a good idea to consult your vehicle's manual or a repair guide specific to your car before proceeding.
Tools and Materials Needed:
Socket and wrench set
Screwdrivers (flathead and Phillips)
Trim panel removal tool
Replacement window motor
New window regulator (if necessary)
Shop rags
Safety glasses
Gloves
Step 1: Disconnect the Battery
Safety first! Disconnect the negative terminal of the vehicle's battery to prevent any electrical mishaps while working on the window motor.
Step 2: Remove the Door Panel
Use a trim panel removal tool or a flathead screwdriver to gently pry off the power window switch panel from the door panel. Disconnect any electrical connectors.
Remove any screws securing the door panel to the door frame.
Gently pull the door panel away from the door frame. You may need to use the trim panel removal tool to release the plastic clips securing the panel.
Lift the door panel up and away from the door frame. Be careful not to damage the wiring or door handle linkage.
Step 3: Access the Window Motor
Locate the window motor, which is typically attached to the window regulator inside the door. The window regulator is responsible for moving the window up and down.
Disconnect any electrical connectors attached to the window motor.
Step 4: Remove the Window Motor
Using a socket and wrench, remove the bolts or screws securing the window motor to the door frame. The exact number and location of these fasteners can vary, so refer to your manual or repair guide.
Carefully remove the window motor from its mounting position. Pay attention to any shims or spacers that may be present.
Step 5: Install the Replacement Window Motor
Position the new window motor in place, aligning it with the mounting holes in the door frame.
Insert and tighten the bolts or screws to secure the new window motor.
Step 6: Reconnect Electrical Connections
Reconnect any electrical connectors that were disconnected from the old window motor.
Double-check that all connections are secure.
Step 7: Test the Window Motor
Reconnect the negative terminal of the battery.
Test the new window motor by operating the power window switch. Make sure the window moves smoothly up and down without any issues.
Step 8: Reassemble the Door Panel
Carefully position the door panel back onto the door frame.
Press the plastic clips back into their corresponding openings on the door frame.
Reattach any screws that were removed earlier.
Reconnect the electrical connectors to the power window switch panel.
Press the power window switch panel into place until it clicks.
Step 9: Test the Window and Finalize
Test the power window to ensure that it operates correctly.
If everything is functioning properly, turn off the vehicle and reattach the door handle and any other components that were removed.
Remember that this is a general guide, and the specific steps and fasteners might vary based on your vehicle's model and the condition of the components.
Mar 7, 2009 at 2:05 PM
