what can i do about the whining noise coming from the power steering pump?
Feb 18, 2009 at 5:01 AM
TEAG
MEMBER
Check the fluid level and add if needed. If that dont do the trick....you may need a new power steering pump. Also check for damaged or kinked lines coming off the power steering pump. Good luck :)
