1999 Chevy Lumina power steering binding , whining noise
1999 CHEVROLET LUMINA
153,700 MILES • 6 CYL • FWD • AUTOMATIC
PABLO-G
what can i do about the whining noise coming from the power steering pump?
Feb 18, 2009 at 5:01 AM
TEAG
  • 158 POSTS
Check the fluid level and add if needed. If that dont do the trick....you may need a new power steering pump. Also check for damaged or kinked lines coming off the power steering pump. Good luck :)
Feb 19, 2009 at 12:20 AM
