1999 Chevy Lumina PARASITIC DRAW
124,000 MILES • 6 CYL • FWD • AUTOMATIC
POLARMANN
wE HAVE A PARASITIC DRAW ON THE BATTERY. aFTER PULLING FUSES IT APPEARS TO BE #10 (15 AMP)WHICH IS I/P ELECTRONICS BATTERY. WHAT IS THAT AND WHAT DO WE DO NEXT?
Jun 21, 2009 at 3:03 AM
DOCFIXIT
  • 18,828 POSTS
O.K. I am impressed you know what a parasitic drain is and how to locate. Fuse controls seat belt/key warning light alarm, theft deterent system,radio,Data link connector and electronic brake control module. If it was seat belt you would see and hear it key out scratch that, theft needs power key off, Radio no brainer, DLC no way, Elect brake module maybe. How many amps is draw? what's meter drop to when # 10 pulled?
Jun 21, 2009 at 8:46 AM
POLARMANN
Thanks for your quick responce and sorry for the delay in replying to your question-it killed the battery. New battery now.. we think there is a 2.0 amp draw-when 15 amp #10 is put back in the draw is 2.8amp -does that narrow it down? Is 2 amp normal or too much?
Jul 1, 2009 at 2:24 AM
DOCFIXIT
  • 18,828 POSTS
Allowable draw is .5mAmp your way over. Need to start unpluging components. Do you have a manual with wiring diagrams? will need Behind glove box is anti-theft module and seat/key warning relays. Locate and pull them see if amps drop.
What is amp draw #10 out?
Jul 1, 2009 at 5:06 AM
POLARMANN
Hi Thanks for your help -it was the radio.
Jul 20, 2009 at 6:33 AM
DOCFIXIT
  • 18,828 POSTS
Very glad to hear you are a good diagnostision. We can use you in auto field
Jul 20, 2009 at 7:14 AM
