1999 Chevy Lumina Oil Pan Removal
150,000 MILES • 6 CYL • FWD • AUTOMATIC
NESTBUILDERS
Has anyone removed the oil pan on a similar year Lumina? I am in the process of removing. Folowing directions from AllData, Mitchell & Chiltons...I have the engine raised using a transverse engine fixture but I can not get the oil pan out. I need input from anyone that has done the process before. Thnak you!
May 28, 2010 at 7:34 AM
HMAC300
  • 48,601 POSTS
you will need to move the crankshaft so that the wieghts aren't in the way.
May 30, 2010 at 7:25 AM
