1999 Chevy Lumina No power/Engine not revving only while dr
225,000 MILES • 6 CYL • FWD • AUTOMATIC
GALLUSCAPPRUS
The car starts ok, will pick up some speed and get out of the driveway but while I'm on the road I can stomp the gas pedal and it will not seem to get any response from engine, but it will occasionally "catch" and give power but then becomes unresponsive again. Gets power fine in 1st, 2nd, but not in drive.
Apr 29, 2009 at 12:39 PM
  • 110,248 POSTS
Has the check engine light come on? Have you checked the catylatic converter to see if it is plugged? Have you had the fuel pressure tested / fuel filter replaced?
May 8, 2009 at 6:16 AM
