1999 Chevy Lumina fuel pump relay ground supply
1999 CHEVROLET LUMINA
NEELYM
Electrical problem
1999 Chevy Lumina 6 cyl Two Wheel Drive Automatic
What supplies the ground to the fuel pump relay?
May 24, 2008 at 3:19 AM
Black and White/E9 terminal
https://images.2carpros.com/forum/automotive_pictures/12900_fp2_4.jpg
see below
May 24, 2008 at 3:34 AM
NEELYM
I have replaced the fuel pump and the fuel pressure regulator and that fixed the fuel pressure problem, but now I can't get the fuel pump relay to engage without suppling an external ground to the ground post of the relay. I guess my question would be is there a sensor or something else that would complete that curcuit?
May 24, 2008 at 4:41 AM
BMRFIXIT
  • 19,053 POSTS
If its the ground wire (blk/wht)
that you are having an issue with
then check the ground wire at the tranny stud bellhousing
or you can run a new wire
this blk/wht wire like ( RAS ) showed it goes straight to tranny ground stud
May 24, 2008 at 6:40 AM
