1999 Chevy Lumina Fuel Problem?
101,000 MILES • 6 CYL • FWD • AUTOMATIC
NATL128705
This car has been behaving badly lately, starts hard sometimes but still gets going, just like it has to turn over an extra time instead of firing right up, and when I'm driving it accelerates a little sluggish sometimes, or it's like there is a little catch or a sputter in it but then it runs fine, it's had the plugs, wires, and coil packs, all recently replaced. Fuel filter, or pump, I dunno? and how do I check this stuff?
Jan 23, 2010 at 7:38 AM
  • 75,988 POSTS
Fuel filter, or pump, I dunno? and how do I check this stuff? By using a fuel pressure gauge designed for your fuel system and hooking up on the fuel rail test port and also test the fuel pump relay and coolant temperature sensor
Jan 23, 2010 at 8:07 AM
