1999 Chevy Lumina Engine Revs, will not go.
CMPINGGRL
  • 7 POSTS
Transmission problem
1999 Chevy Lumina 6 cyl Automatic 138000 miles
My 1999 Lumina was driving fine. Then it just would not get into gear. It will try and accelerate when stepping on the gas pedal, but the gears will not catch or something. I do have a transmission line leak, and am going to try to put transmission fluid in to see if that solves the problem. IF it doesn't, what could be the problem?
Oct 23, 2009 at 8:40 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Well with leak maybe low so check an add if needed. If that does not help then wrecker to shop so trans can be checkout.
Oct 23, 2009 at 8:48 AM
