1999 Chevy Lumina Engine Hesitating
1999 CHEVROLET LUMINA
184,000 MILES • 6 CYL • FWD • AUTOMATIC
WILLIESURVIVE
Hi. I am new to this site. I hope you'll can help. I have an occasional problem with my car, especially on Mondays when I don't run the car all weekend. On monday mornings, I take off to work. Like around a mile or so, I step on the accelerator and the car starts to jerk, stutter, like it wants to die and I can't give it gas. It does this for a few seconds then goes away. I then give it gas to go faster then it starts again like hesitating real bad then it goes away for a few seconds. Like around 10 miles doing this, it slowly goes away. It doesn't do it in the evening when I go home. Could it be moisture or a gas problem? or electrical? I have replaced the crank shaft sensor twice cause it would just completely turn off on me. Could it be my spark plugs? It has been a year since I changed them and since then I have had this problem. I just recently replaced the wires and it still does this. What do you suggest? It used to do it more often when I let the gas gauge go low so since then I have had at least a quarter of a tank or more but I today I had half a tank and it did it this morning on a Thursday... What do I do?
Jun 10, 2010 at 5:38 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 10, 2010 at 11:55 AM
