1999 Chevy Lumina Dashboard Voltage Light (and other lights
1999 CHEVROLET LUMINA
KENOSHAAL
Electrical problem
1999 Chevy Lumina 4 cyl Two Wheel Drive 147000 miles
I am trying to determine if I have a problem with the alternator or other electrical problem or not. I've always had false problem lights show up on the dashboard, such as service engine soon. My dashboard started to go dim some months ago, and recently I replaced a dead battery with a used, less powerful one. Now, the volt light is going on, which never lit up before. The car has been starting, but how can I determine what the problem, if any, might be?
Thanks,
Al
Jan 26, 2010 at 3:52 PM
SCOTTY DEE
  • 592 POSTS
The first thing is a charging system test. This will test alternator, battery, starter.
A voltage problem could cause some issues with the cluster. The service engine soon light is not a false light. When that light comes on there is a trouble code stored in the PCM (powertrain computer).
Let me know what you find out.
Jan 27, 2010 at 3:31 PM
