1999 Chevy Lumina Brake lights and turn signals
1999 CHEVROLET LUMINA
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
TERCIR2006
When I step on the pedal the main brake lights do not light. The third light in the rear window does light. None of the turn signals work. The four way flashers work - the bulbs are good, the fuses are good.
Is there a blinker control module, and can that affect the brake lights as well?
May 1, 2009 at 11:57 AM
You need to get the turn signal switch tested thoroughly it has to go thru here for the brake/turn signal to work
May 1, 2009 at 12:12 PM
