1998 Chevy Lumina why does center window brake light light
113,000 MILES • 6 CYL • FWD • AUTOMATIC
FLAGG911
i have 1 1998 chevy lumina?
I have a problem where when I hit the brakes only the center brake light comes on and not the side ones. the running lights al;l work and the bulbs check out. what do i do and where do the brake wire split after the center light>
Feb 9, 2009 at 9:43 AM
  • 110,248 POSTS
Hi:
check the light sockets. See if you are getting power to them. If you are, the sockets are bad.
As far as the wiring, I believe the 3rd brake light gets power last.
Let me know what you find.
Feb 10, 2009 at 6:14 AM
