i was woundering if you could tell me the best way to get the trans out ? do you pull the motor or the a frame ? please help . Thanks in advance
Mar 14, 2009 at 7:16 PM
TEAG
MEMBER
You dont have to pull the motor or frame. Just have a few jacks. Youll have to drop the exaust. Besides that.......no other major systems have to be removed. There is alot of work to this job. Its not easy. You just disconnect and drop it out once evrything is clear.
Mar 16, 2009 at 6:43 AM
