1998 Chevy Lumina sputtering and cutting off
1998 CHEVROLET LUMINA
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
KZAMBRON
i just bought this and from the owners house to the garage for an oil change, the engine when i arrived at the garage it started sputtering and cutting out. He has had it for 2 days and cant get it to do it again but the owner said it has been doing that for awhile.
Mar 23, 2010 at 11:57 AM
Inspect and test all the following listed below and get back with some testing results we start here
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 23, 2010 at 12:04 PM
