1998 Chevy Lumina Shifting out of park
1998 CHEVROLET LUMINA
91,200 MILES • 6 CYL • FWD • AUTOMATIC
BADGER4871
Sometimes I try to shift out of the park position the shift button will not release the console shift lever. I can get it loose but it is really hard to do. The brake pedal is depressed when I attempt to shift out of park. I have tried squirting a little oil in the button on the shifter, but it still seems like it might have a barb on it. Once it breaks loose it seems alright for a few days. Can you help with a solution?
Aug 30, 2010 at 10:37 AM
WRENCHTECH
  • 20,761 POSTS
Another thing you don't want to do is run that compressor with a jumper ito it. When you do that your running it without the condenser fan and that will send the pressure to explosive points and take out your compressor.
Aug 30, 2010 at 11:16 AM
