1998 Chevy Lumina Rear Wheel Alignment
134,000 MILES • 6 CYL • FWD • AUTOMATIC
FRANKIE
Due to front ball joint failure and replacement, I took the car for a wheel alighment. Front aligned OK. BACK aligned 1/2 OK, "The passenger side Toe is 0.58 and there is no more adjustment. Go to a chassis place."
To begin with, who knew there was a rear alignment!I Can't find a place to fix this.
More facts: Total rear toe 0.64, Thrust angle -0.26 degrees, all according to Tire Kingdom.
No accidents, springs good, no visible evidence of bent parts. Is this an OEM defect? How do I get it fixed in Hollywood FL?
Thanks
Frankie
Nov 21, 2008 at 8:19 PM
DENNYP
  • 1,824 POSTS
Something has to be bent somewhere. It could also be a bad bushing in the suspension. The other possibility is the alignment wasn't done properly.
Nov 22, 2008 at 1:58 AM
