1998 Chevy Lumina PCV Valve Replacement
MARK MOON
Engine Performance problem
1998 Chevy Lumina 6 cyl Front Wheel Drive 220,00 miles
The engine has begun to run rought. No problem ideling but it begins to sputter when accelerated. I recently replace the fuel filter. Would the problem be the PCV valve needs replacement? It has not been replace for at least 100,000 miles.
Jun 16, 2010 at 6:49 AM
RENAUDTN
  • 636 POSTS
Could be PCV, but could be many other things as well. A new PCV won’t hurt; it’s cheap, and takes two minutes to replace so you might as well do it. By the way, do you have any code?
Other possibilities include:
Bad MAF
Bad TPS
Bad MAP
Low fuel pressure
Problem with ignition system
Dirty injectors
Problem with EGR
Vacuum leak
Jun 16, 2010 at 7:49 AM
