1998 Chevy Lumina My car squeaks and creaks when I go over
128,000 MILES • 6 CYL • FWD • AUTOMATIC
GAVINSMOM05
I was told that it could be several things. The squeaks are small and intermittent, and get louder when I hit bigger bumps. It also squeaks and creaks at slow speeds (such as when I am pulling into my driveway). Could it be struts? Springs?
Thanks
Suzanne
Jul 25, 2009 at 9:25 AM
  • 110,246 POSTS
I doube the struts are making the noise. However, it could be the rubber they are mounted in. Also, check to make sure the sway bar bushings are not dried out and causing a noise. I will usually spray all rubber parts down (one at a time) with a libericant like WD 40 to see if and when the sound goes away.
Jul 26, 2009 at 3:17 PM
GAVINSMOM05
I have an oil change appointment in a couple days, is your suggestion easily accomplished, or are they going to need a while?
Jul 27, 2009 at 11:50 AM
  • 110,246 POSTS
It is easy, and should take about 2 minutes.
Jul 28, 2009 at 4:04 PM
GAVINSMOM05
They lubed the bushings in the rear and it's still squeaking. Are there bushings in the front? Why couldn't it be the struts?
I am at a loss without having to take it to a garage and have them tear it apart to see what it is.........
Jul 29, 2009 at 9:23 AM
  • 110,246 POSTS
Yes there are bushng in the front. As far as the struts, they normally don't squeak. When they go bad, normally they just get soft over bumps or will allow the car to continue bouncing.
Jul 29, 2009 at 11:08 AM
